Greetings:
I have a pair of SUB-20-R25s (FW v0.2.2) that (initially) I'd like to set up to communicate between each other using SPI Master & Slave. I have connected J6 pins 1-3-5-7-10 in a one-to-one fashion between the two SUB-20s. I have tried (without success) to morph the SPI examples included in the Windows distribution into a usable interface, but I am getting no where fast. Do you have a LabVIEW example that performs this operation?
Additionally, it seems that the Dot-Net documentation included with the Windows install hasn't kept pace with the APIs. Specifically I see several functions in the Sub20 and Sub20Enum classes that aren't defined in the Oct 30, 2009 version of Sub20net.doc. Is there an updated version of the documentation available?
Dave
SUB-20-R25 SPI Master-Slave Comm
puneetkapoor
Re: SUB-20-R25 SPI Master-Slave Comm
Hi..
Have you tried .net interface in labview for communication with dimax kit ?
If you have any specific problem with the codes, may i help you.
Puneet
Puneet
Hi Dave.Dave wrote:Greetings:
Dave
You need to configure one board as SPI Master and another as SPI Slave.
Assuming you are using SUB-20 Tool.
- Master operations are controlled from SPI tab.
- Slave fifo config and read/write can be done via FIFOF tab.
What exactly?Dave wrote:Greetings:
Dave
