SPI configuration
dsp28x
SPI configuration
Post by dsp28x »
Does sub20 SPI_read and SPI_FIFO_Read have supports in Matlab? Because this 2 function does not work.
% SPI data read
if ~ sub20.SPI_Read(Data, Arr)
% SPI FIFO read data
if ~ sub20.FIFO_Read(Data,10,64,10000)
There is error all the time.
??? No method 'SPI_Read' with matching signature found for class 'Xdimax.Sub20'.
??? No method 'FIFO_Read' with matching signature found for class 'Xdimax.Sub20'.
Are there any Matlab examples code or how one can use this functions.
Re: SPI configuration
% SPI data read
The SPI_Read accepts three arguments. The following call is correct
success = sub20.SPI_Read(Data, 2, sub20.SpiSS_H);
The same for the FIFO_Read method. It accepts three arguments as well and returns status and number of bytes actually transferred
[success transferred] = sub20.FIFO_Read(Data, 1000, 0 );
See the sub20.net document for more information
dsp28x
Post by dsp28x »
Thanks serg, it helps :) .
dsp28x
