Where can I find the documentation on how this works.
Thanks!
John
RELEASE
Re: RELEASE
After you install it you will get PDF file with API documentation.
I have also attached it to previous post
Re: RELEASE
Hi again,
I did find this documentation. I guess the real question is, sometime ago I had asked if it would be possible to manually drive the CS bits that are not being used by the SPI as extra GPIO bits. This feature existed in the USB12, and I discovered that it was not available in the SUB20.
So I was wondering if this capability has been added.
Thanks allot!
John
Thanks allot!
John
Re: RELEASE
Hi
It's on the way. Will be ready in next release.
Re: RELEASE
The documentation here is always full, I'm happy to join the forums!
