Page 5 of 5
Re: SPI data transfer issue
Posted: Mon Jul 25, 2011 10:28 am
by amaitra
No problem. Thanks for your help so far.
Just tell me - why did you suggest the configuration you did. That is all I want to know. Because we might end up using sub-20 in another applications as well.
Thanks in advance.
Regards,
Amit
Posted: Mon Jul 25, 2011 2:39 pm
I used this:
Clock Phase And Polarity: The LTC6802-2 SPI compatible
interface is configured to operate in a system using
CPHA = 1 and CPOL = 1. Consequently, data on SDI must
be stable during the rising edge of SCKI.
It means you can sample on rising edge
Data Transfers: Every byte consists of 8 bits. Bytes are
transferred with the most significant bit (MSB) first. On a
write, the data value on SDI is latched into the device on
the rising edge of SCKI (Figure 6). Similarly, on a read,
the data value output on SDO is valid during the rising
edge of SCKI and transitions on the falling edge of SCKI
It means setup on falling edge.
Posted: Mon Jul 25, 2011 2:41 pm
I assume SDI is data from IC to SUB-20 and
SDO is from SUB-20 to IC
If it is vice versa you will need instead SETUP_SAMPLE
Posted: Mon Jul 25, 2011 4:41 pm
by amaitra
Thanks!
Amit
