MS Visual C++ 2010 Express Addition
obsidian
Post by obsidian »
Till now I have been using MS Visual C++ 2008 Express for compiler. In moving to MS Visual C++ 2010 Express the sample project goes through a conversion step, which fails. I.e. no converted project is built, and there are many errors.
Any suggestions on how to make this work, or other free tools that can be used to read the project files.
Thanks
Re: MS Visual C++ 2010 Express Addition
What project do you convert ? The sub-win project is MFC-based. As far as I know the free MSVC2010 doesn't include the MFC library. Can you please send us the conversion log file?
obsidian
Post by obsidian »
Since Mingw is now working I have moved on.
Note however that I am using sub_app, so MFC should not be an issue.
Also, sub_app converts and compiles fine on MS VC 2008 Express.
Thanks anyway
If you will need to build the sub_app by MSVC anyway, try to create a console app project and add two files to it: sub_app.c & cmd_pars.c. Don't forget about the sub20.lib
