Latest SUB-20 RELEASE
Locked
SUB-20 FW 0.4.5
Fixed BB I2C clock stretching
SUB20-0.4.5.INC
(74.71 KiB) Downloaded 1134 times
See SUB-20 Firmware Update)
LabView .NET v4 packages
SUB20 v1.2 LV2016x64.zip
(1.31 MiB) Downloaded 1061 times
SUB20 v1.2 LV2016.zip
(1.29 MiB) Downloaded 962 times
SUB-20 FW 0.4.3
Fixed BB I2C read for channels 1,2,3
SUB20-0.4.3.INC
(73.85 KiB) Downloaded 1439 times
SUB-20-NET-1.4.27.zip
SUB-20 /NET interface module ver. 1.4.27
Added full 64-bit support to the following methods in the 64-bit version of the .NET component
Sub20Enum::GetNext
Sub20::Open
Sub20::GetHandle
Sub20::CloseHandle
Sub20::GetHandle_i
Sub20::CloseHandle_i
Download
http://www.xdimax.net/download/SUB-20-NET-1.4.27.zip
Linux Snapshot SUB-20-snap-130926
Download:
http://www.xdimax.net/download/SUB-20-snap-130926.tgz
SUB-20-NET-1.4.22.zip
SUB-20 /NET interface module ver. 1.4.22
Fixed bugs
- Invalid handle returned during device enumeration on 64-bit platform
Download
http://www.xdimax.net/download/SUB-20-NET-1.4.22.zip
SUB-20-120622
New features:
- Unified Installation package for Win2K/XP/Win7 32/64 bit
- 32-bit development support on 64 bit OS
- SPI devices support for the programmer in SUB-20 Tool
- Added more sample projects
Versions:
.NET interface 1.4.20
Firmware 0.3.6
SUB-20 Tool 1.6.16
Note: BINARY FILES AND .NET COMPONENT PATH
Please note that starting from this version the path to binary files including the.NET component has been changed from
C:\Program Files\SUB-20\bin to C:\Program Files\SUB-20\bin\x64 and C:\Program Files\SUB-20\bin\x86.
This is done to support development for both 32/64 bit apps on a 64-bit OSes. Please change the reference path in your projects accordingly.
Download
http://www.xdimax.net/download/SUB-20-120622.exe
SUB-20 Driver Installers:
http://www.xdimax.net/download/SUB-20-d ... 22-x32.exe
http://www.xdimax.net/download/SUB-20-d ... 22-x64.exe
http://www.xdimax.net/download/SUB-20-d ... 22-w2k.exe
SUB-20-120121
New Features:
- SUB-20 SW Reset
- SUB-20 Internal EEPROM Read/Write
- Minor bug fixes
Versions:
Firmware 0.3.5
Library 027
Download
http://www.xdimax.net/download/SUB-20-120121-x32.exe
http://www.xdimax.net/download/SUB-20-120121-x64.exe
http://www.xdimax.net/download/SUB-20-120121-w2k.exe
SUB-20-110912
New Features:
- Low Speed SPI option with CLK frequency 100.000K .. 4000K
Versions:
Firmware 0.3.3
Library 025
Download
http://www.xdimax.net/download/SUB-20-110912-x32.exe
http://www.xdimax.net/download/SUB-20-110912-x64.exe
http://www.xdimax.net/download/SUB-20-110912-w2k.exe
FW update to version 0.3.3 required (see SUB-20 Firmware Update)
SUB-20-110611
New Features:
- High Speed I2C (HS mode) (http://www.xdimax.com/sub20/doc/HTML/sub_i2c_hs_rw.htm)
- 4MHZ MDIO CFP MSA Support (http://www.xdimax.com/sub20/doc/HTML/sub_mdio_xfer.htm)
Versions:
Firmware 0.3.2
Library 024
Download
http://www.xdimax.net/download/SUB-20-110611-x32.exe
http://www.xdimax.net/download/SUB-20-110611-x64.exe
http://www.xdimax.net/download/SUB-20-110611-w2k.exe
FW update to version 0.3.2 required (see SUB-20 Firmware Update)
SUB-20-110317
New Features:
- Edge Detector: http://www.xdimax.com/sub20/doc/HTML/edge_detector.htm
- I2C Disable
Versions:
Firmware 0.3.1
Library 021
Download
http://www.xdimax.net/download/SUB-20-110317-x32.exe
http://www.xdimax.net/download/SUB-20-110317-x64.exe
http://www.xdimax.net/download/SUB-20-110317-w2k.exe
Linux Snapshot
http://www.xdimax.net/download/SUB-20-snap-110319.tgz
FW update to version 0.3.1 required (see SUB-20 Firmware Update)
SUB-20-101021
New Features:
- SPI Transfer with Extended Slave Select control: http://www.xdimax.com/sub20/doc/HTML/su ... er_ess.htm
Versions:
Firmware 0.2.9
Library 019
SUB-20-100817
New Features:
- 4 Bit-bang I2C Master Channels
- IR Support
- MDIO2
- Support FIFO_READ_FULL flag
- GPIOB
Versions:
Firmware 0.2.8
Library 018
FW 0.2.2
http://www.xdimax.net/download/SUB20-0.2.2.zip
SUB-20 .NET v1.5
- Added OpenByIndex(int Index) method
sub20dnc_v1.5.zip
(107.08 KiB) Downloaded 507 times
Locked
