Identifying multiple Sub-20s
My computer is connected to two or more sub-20 devices. One of the device is configured as master and the other in slave mode. We are doing SPI as well as GPIO transactions. How do I identify which device descriptor corresponds to which device. Please help
Re: Identifying multiple Sub-20s
Each SUB-20 device has unique serial number.
To distinguish devices you need to use it's serial number:
http://www.xdimax.com/sub20/doc/HTML/su ... number.htm
Will quire serial number of the device with given handle(descriptor)
int sub_get_serial_number( sub_handle hndl, char *buf, int sz)
Thank you for the reply:):):)
I have two sub-20s connected to my computer. So I stored its serial number in a file and while running the program, I open the device and get its serial number and check it with the file, and if it is same continues, otherwise closes that device and continues searching for the next device. And I am running two instances of that program (lets call it pgm1 and pgm2), one for each sub-20. But there is some problem. If I run pgm1 first and then pgm2, there is no problem. But if I run pgm2 first and then pgm1, pgm1 is not able to open the device.
The code is given below
all necessary variables are initialised globally
//Function to open the SUB-20 device
int gpio_sub_dev_open()
dev = NULL;
int i=0;
char sn_buf[5];
int error_port;
sub_hnd = NULL;
while(dev = sub_find_devices( dev ))
sub_hnd = sub_open( dev );
if(!sub_hnd)
printf("ERROR: Cannot open handle to device\n" );
return -1;
rc = sub_get_serial_number( sub_hnd, sn_buf, sizeof(sn_buf) );
if(rc<0)
printf("ERROR: Cannot obtain serial number: %d\n", rc );
return -1;
if(strncmp(sn_buf,file_sub20_serial_num,strlen(file_sub20_serial_num)) == 0)
else
sub_close(sub_hnd);
Please help:)
dev = NULL;
int i=0;
char sn_buf[5];
int error_port;
sub_hnd = NULL;
if(!sub_hnd)
return -1;
if(rc<0)
return -1;
else
sub_close(sub_hnd);
Please help:)
When pgm2 runs at first place it looks like it doesn't close the first device handle. Please send a compilable project, so we will be able to reproduce your issue and debug it.
