sub_fifo_read() returns -7
I',m using sub_fifo_read() and returns -7. Anyone please explain why it is happening?
Re: sub_fifo_read() returns -7
What is your target OS version, SUB-20 software package version, how to reproduce your issue?
Target OS is ubuntu 10.01 and software package version is SUB-20-snap-100910.
In my project, I have a master and configured sub20 in slave mode. Master sends data through spi. So I need to read that value
Try the SUB-20-snap-110319.tgz with the following fix:
change the libusb.c, line 1989
from
to
from
rc = libusb_bulk_transfer( hndl, SUB_FIFO_IN_EP, (unsigned char*)buf,
rc = libusb_bulk_transfer( hndl, SUB_FIFO_IN_EP, (unsigned char*)tmp_buf,
I had done what you had said but still I'm getting the same error. .... ;-(
In my system I had a master which sends the data which is to displayed in LCD of resolution 128 X 64. So it will send maximum of 1024 bytes of data. So I need to read all of them and corresponding gpio value of each byte of data. For reading I'm using sub20 which is configured in slave mode and data is read using fifo. And here I'm having the problem. The function sub_fifo_read() is returning -7.
